An optic module of a particular type has been inserted into a port which is not configured correctly for it.
Change the configuration of the port to be correct for the optic module, or remove the optic module from the port and replace it with one for which the port is correctly configured.
Warning
The configuration for the %optic% optic module is not correct - please configure port %slotPort% for auto-negotiation %autoNeg% and speed %speed%
| Name | Type |
| optic | String |
| slotPort | SlotPort |
| autoNeg | String |
| speed | uInt |
